hybrid d series?
hybrid d series?
ok heres the deal.... i just traded my 89 Si for a 93 CX... but the CX is gutless!!!!! my brother has a single cam VTEC motor from his 94 Si hatch with spun bearing in it... can i use the head and manifolds off that on my CX motor?
Re: hybrid d series? (JDMinPorterville)
hmmm...i know you can do a mini me swap...but ive heard of doing it with the d16y7 and the d16y8 head....not sure exactly what you need to do it...try the search for mini me swap.
if that cx has a d15b8 8 valve engine dont use anything from it. swap the complete z6... if your brother wont give you the head, your better off with a non vtec head than the one you have. but this is only relivant if it is a d15b8
Re: hybrid d series? (Zer0DazE)
Well zero not to be a jerk but you are wrong, if done correctly you can yeild more horsepower from a mini-me swap than just doing a full swap do to the increase in compression. check this website for info
http://crx.honda-perf.org/articles/z6swap/z6swap.html
walks you through the full swap.
Re: hybrid d series? (twitchm80)
i understand that, but if its the 8 valve head he is putting on... the z6 has a 16 valve engine. not to mention the z6 has larger valves.
read his post and you will see he is doing the oppostie of a mini me, by using a 1.6 bottom end and a head designed for fuel economy.
dont use a 8 valve block unless u put 16 valve pistons in it..with a 16v head swap. if u dont u will have pistons with only 2 valve reliefs per cylinder when the head calls for 4 per cyl.
New User
Re: hybrid d series? (JaeOne3345)
New User
"can i use the head and manifolds off that (the 'that' here refers to the z6) on my CX motor?"
New User
duneracer69
14
01-03-2006 04:25 PM
civicmatt
01-08-2003 10:43 PM
civicmatt
07-30-2002 07:05 PM
