Vafc anybody having troble with them???
is anybody have alot of **** with these.. i am an one of my homebois is having problem too. its hook up rite but on my bois its cutting the fuel out at the top end and for me im throwing engine codes. do anybody have any answers to this problem.. also im running a spoon sport ecu if thats helps
Re: Vafc anybody having troble with them??? (Houston Hatchback)
did you crimp the wiring or sauder it ? i would recomend saudering it (made a world of diference on mine) Also check where it was grounded mine was grounded in the wrong place and it caused my throttle to blip. Who did the install? If you did I would recomend taking it to a shop and let them check it out . Then get the car on a dyno and let them tune it and set it . Once thats done leave it alone (dont mess with the settings cause you can damage the motor!) Good luck
did you check the CEL to see what code its throwing?
Re: Vafc anybody having troble with them??? (JC)
naw everything is good 6 in and 6 out but i think i need to get it tuned.. but im not going to pay 250 just for some dyno run. im going to wait untill i get some turbo or better cams.
Here hopefully this will help you.
VAFC Tuning1
VAFC Tuning2
This is just a setup guide. Go through it and make sure everything checks out. Then get it tuned.
VAFC Tuning1
VAFC Tuning2
tpr
08-13-2005 09:10 PM
