Good Cam gears
Re: Good Cam gears (powaycivic04)
i personally like the toda spockets. they have a different and more accurate degree markings. also easy to set them to tdc f you have a milled head, etc. also the new str sprockets are basically toda copies.
check out Fidanza cam gear, superb quality, and cheap, 5 bolt locking
only $152 for a pair and thats shipped ( I got a pair)
http://www.alamomotorsports.com/prod...m/blowout.html
[Modified by eg6ajk, 7:09 AM 6/13/2002]
big strong guy
Re: Good Cam gears (Jason kiDD)
i had a faulty jhp gear, does the ol wobbley on the cam! made it hard to tighten belt right! i dont recomend them, spoon and jun seem to be nice! i like gears that use factory ring! good luck, eric
Re: Good Cam gears (KJEG94)
Todas run $300 a pair, but you could find a good deal around here if you keep looking.
I will probably invest in the Skunk2 units. I have yet to hear anything negative about them. And at about $180 a pair they don't break the budget.
Re: Good Cam gears (WAFFLES)
get either one from the big three. Spoon,Toda, and Jun, theyre made of tougher materials and you'll never lose place of the degree markings because they are engraved. i think jun makes gears for the sohc engine, or was it toda. I know that it's one of the two.
Re: Good Cam gears (vtecvoodoo)
does anyone have the new STR gear? looks good i heard the same thing about how they copied the Toda gear. it supposedly has the same finish as the Moogen MF8's
Mr.Integra
11-03-2001 09:03 PM
