camber on a 00 si
camber on a 00 si
hey guys i have a question. i have a 00 si and i put two washers for the rear camber and it still looks like it has a lot of negative camber. i only have about an 1.75 drop. can it be that my LCA is bent?
or should i just put one more washer on each side?
thnx for the help guys.
Re: camber on a 00 si (qbsi)
I have a '99si I have a 2.5in drop my car has major neg camber my friend did the same thing you did and it still has some camber you won't be able to make perfect I don't hink.
Re: camber on a 00 si (Bagel Williams)
I have my car dropped around 3" and I did the two washers trick. It helped out quite a bit, but it still isn't perfect. However, it is corrected enough to where you won't see significant tire wear. I would be more worried about the front camber. All of your is coming from the front of the car. Also, make sure your alignment and toe are back to factory setttings.
Re: camber on a 00 si (96 SOHC VTEC)
ok thnx for the help guys.
i think i might try to get a longer bolt and put one more washer on each side tomorrow and see how it looks.
sk8shorty012
23
11-14-2006 10:59 AM
Burgh
15
11-24-2004 04:25 PM
