99 Si motor into EG
Re: 99 Si motor into EG (rudy 94 si)
im pretty sure the rear fits.... not that i've experienced it myself.... considering that its B series they should go together..... good luck.......
Re: 99 Si motor into EG (DOHCtorTHRUST)
I had the shop hack up both the D series mount and the B series mount to make a "hybrid" mount ......works really well. Nice welds. I would have used a del Sol VTEC mount, but it was a Sunday and the dealership was closed and we wanted to finish up.
Works nice. probably stronger than stock!
Steve
Steve
1 Post
Just buy a set of GSR mounts. That's the easiest thing to do. No point in welding all that stuff.
You can sell all the Si mounts for basically the same price of the GSR ones.
Re: 99 Si motor into EG (fowler)
Yes, the 99 Si rear mount bracket is too short....but the GS-R bracket does not bolt on my car....different hole locations on the engine side of the bracket (99 Si transmission/ 98 ITR block).
Re: 99 Si motor into EG (TodaSi)
That's what we found, and hence the need to cut and weld. I think that probably a del Sol VTEC bracket would work, but I have no idea if the subframe mount point is different between Civics, del Sols and Integras.......
Steve
Steve
Metal Head
05-01-2006 02:33 PM
nicknasty
11-19-2003 04:17 PM
nicknasty
11-19-2003 02:30 PM
lowboost civ
03-09-2003 07:23 PM
