Short shifter saw
Old 06-13-2002, 11:50 AM
Ekco's Avatar
Default Short shifter saw
I have a neuspeed shifter and I want to saw it down so the shifter is lower inside the car. Only problem is that the neck of the shifter gets fatter as it goes down and it is at kinda of a angle
I thought about putting it on the lathe and turning it down so a shift **** will fit on
Anyone have any suggestions?
Old 06-13-2002, 12:18 PM
turboman's Avatar
Default Re: Short shifter saw (Ekco)
back in the day before I even heard of a short shifter I had a fiero gt.
I didn't like how tall the shifter was and realized that by cutting it I would shorten how far I'd have to move it to make a shift.
If I would have known how popular it would be I'd be rich now.
I took it to a machine shop around the corner and had about 2 inches cut off and then they cut thread into the shaft some how. It worked great although I might have had it cut to short. Needed alot of strength to shift.
Old 06-13-2002, 12:22 PM
Ekco's Avatar
Default Re: Short shifter saw (turboman)
But on the neuspeed shifter the neck gets bigger as it goes down, so I won't be able to fit shift **** on even after I rethread it.
Any suggestions?
Old 06-13-2002, 12:26 PM
FifthGearOnline's Avatar
if you want to do that.....you could use a dremel tool
Old 06-13-2002, 12:28 PM
Ekco's Avatar
Default Re: Short shifter saw (FifthGearOnline)
A dremal tool how?
Old 06-13-2002, 12:30 PM
Urban Made 93EX's Avatar
Get a Short shifter by DC Spors it drops it real low and it has 4o percent beter throw.
Old 06-13-2002, 12:32 PM
Ekco's Avatar
Default Re: Short shifter saw (Urban Made 93EX)
Lower than the neuspeed? I want it about 2.5-3" in shorter. Like a joystick!
Old 06-13-2002, 12:36 PM
Its pretty low and you can get one for about 70-80 bucks. Im inpressed with it. Neuspeed doesnt appear to me as a Japanese performance part mosre strictly to European.
ProjectCD5
02-21-2006 11:55 PM
gameknb
06-11-2005 07:32 AM
starbury
02-15-2005 09:58 AM
SOHC_MShue
06-20-2002 02:44 PM
ArchAngel Sabastian
02-02-2002 12:09 PM
Quick Reply: Short shifter saw
