engine/ecu harness
engine/ecu harness
If i put a B18c1 engine (GSR) into a '98 civic EX, will the GSR ecu/engine plug into the Civic herness or will i need to use a GSR harness or maybe some other kind of conversion??
Re: engine/ecu harness (gsr mike02)
If the motor is a 96-00 GSR it will be plug and play.
If your GSR motor is a 94-95 motor then you will need a Skunk2 ecu conversion harness. This harness wil then make the swap plug and play. They are usally anoutmnd $250
Tunez
10-30-2008 12:51 PM
boostincoupe
09-10-2006 08:34 AM
