Another question about B18C1 swaps
I just bought the engine, and I'm in the process of getting everything together for the install.
What else do I need for the install?
So far, I need:
upper rad hose
cv joint
rear mount
throttle cable
Am I missing anything? Besides of course the obvious engine and tranny. :D
So far, I need:
upper rad hose
cv joint
rear mount
throttle cable
Guest
Posts: n/a
Re: Another question about B18C1 swaps (DRG Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRG Performance »</TD></TR><TR><TD CLASS="quote">I got your answer right here
Impressive use of your 5 posts a day.....
What kind of car is it going into?
EDIT: pwned all those guys
you're a ****** retard. if you don't have anything useful to contribute, stfu.
to the other guy, what kind of car do you have?
Re: Another question about B18C1 swaps (monicle)
96 HB
Also, regarding the CV, I'm assuming it has to be one from/for a Gs-R right? That would make sense.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRG Performance »</TD></TR><TR><TD CLASS="quote">Sorry guys but my nos fogger was leaking and im a little dizzy ya know.
so your head is in the engine bay?
Re: Another question about B18C1 swaps (sexualbanana)
in regards to this question, the car type and year are kinda important factors in this question.
Shift linkage
Mounts
some wire, some soder
a helms manual
Oil
Tranny fluid
New plugs
Shift linkage
Mounts
a helms manual
Oil
Tranny fluid
New plugs
With the exception of the rear mount, what about the other mounts? Do I use the old ones from my original engine?
is the motor OBD2 or OBD1? that will make a difference if the motor is OBD1, in that case you will need a conversion harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexualbanana »</TD></TR><TR><TD CLASS="quote">With the exception of the rear mount, what about the other mounts? Do I use the old ones from my original engine?</TD></TR></TABLE>
you will be using an Si drivers side mount and rear mount i believe. do a search in the hybrid forum.
Re: Another question about B18C1 swaps (DX Generation)
you need to read ... and now I'm dun with you.
You will find all of your answers here http://www.phear7imports.net/s...6gen/
get an si upper radiator hose, it actually has the correct diamter openings so you won't have to ghetto clamp your **** down
UnspokenTruth
05-10-2004 05:32 AM
