B16a trouble
B16a trouble
Ok I got a b16a still obd0. When I drive it and it is below 3500 rpm it sounds and feels like it will load up with fuel and just bog down like it is flooded. I changed sparkplugs,wires,distri,cap and roater, and turned all the fuel settings on the vafc to stock. It is still doing it. It had a ls/vtec in it at one time. I took each plug wire off of the plugs one by one when the car was running and it did what it was suppose to do when you loose spark on a plug. I am still useing the same chiped ecu. Could that be the problem. Another thing is when I put a load on the motor it works great it only happens in normal day to day driveing. Any help would be great.
Christian
Christian
Ryhaz
16
03-16-2014 07:13 AM
yeahkkyle
09-23-2009 02:24 AM
