D16Z6 or D16Y8 Tranny
Is there any differents in these trannys? I looking to get another tranny and wonder which would be the stronger tranny. Or if you have any other ideas that might fit a d series motor.
I am looking to be able to hit good speeds on the highway but not to KILL me 1/4 time.
Re: D16Z6 or D16Y8 Tranny (95cxhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxhatch »</TD></TR><TR><TD CLASS="quote">yes it is a better and newer tranny , as said b4 it has stronger shift forks...they steel compared to aluminum that the Z6 has!!!!</TD></TR></TABLE>
be professional
Re: (nichols_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nichols_si »</TD></TR><TR><TD CLASS="quote">so if i have a d16z6 i can bolt on a y8 trannie in replace of the z6?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">y8 stronger for early syncro wear?</TD></TR></TABLE>
No.
Yes.
No.
Re: (nichols_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nichols_si »</TD></TR><TR><TD CLASS="quote">any re locating or fabing required
for a y8 to take bolt up to my z6 engine in my eg HB?</TD></TR></TABLE>
no relocating or fabbing required just bolt it up fill it up with fluid and go
Re: (nichols_si)
bolts right up!!
you need to reuse the reverse sensor off the z6 since the plugs are different...
OT: But does anyone know where to get a y8 tranny or equivilant online/shipped for cheap?
Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 »</TD></TR><TR><TD CLASS="quote">what is aluminum in the z6 that isnt in the y8?</TD></TR></TABLE>
the shift fork in the z6 is aluminum and in the y8 its steel it will bend before it breaks
Re: (5thGenCivicKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenCivicKid »</TD></TR><TR><TD CLASS="quote">yea the y8 is deff better</TD></TR></TABLE>
only in terms of their shift forks. otherwise, they are the same.
Re: Re: (lawlerlaw)
i've heard that on 96+ , the input shaft seems to have problems more often then they should..but i don't have any personal experience with that issue though...
Re: Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I have had main input shaft bearing problems with 2 97 trannies. </TD></TR></TABLE> I had it myself on my z6 tranny also
Re: Re: (ME SO FST)
My friends y8 has problems with the input shaft (has about 105k on it), but he beats on it daily. My z6 on the other hand has a very slight 2nd/3rd grind (77k)and I bought it off of the 60 year old original owner! So IMO both have their good and bad points.
Re: Re: (lawlerlaw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lawlerlaw »</TD></TR><TR><TD CLASS="quote">well i have 2 friends with y8 trannies and they both have 3rd gear grinds, and my z6 tranny just recently got a 3rd gear grind im not sure which tranny to get now..</TD></TR></TABLE>
3rd gear grind @ high rpm = motor/tranny moving thus causing a grind when you try to go into 3rd
new mounts should fix that...
Re: D16Z6 or D16Y8 Tranny (heyyou82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heyyou82 »</TD></TR><TR><TD CLASS="quote">well, if these two trannies are the same, can you put the steel shift forks from a y8 in to a z6 tranny?</TD></TR></TABLE>
um...y not just throw in the y8, much easier
