Need information or pictures of location of tranmission fluid...
Ok guys, the problem is been my clutch acting funny or my gears, w.e. Well earlier today I bleed my clutch reservior or little cylinder next to the firewall, but still same results with my clutch and gears. Well to my question is where is the transmission fluid bottle located at. Looked for like 20 mintues with a friend in my engine bay and could not find it. The car is a 92-95 Civic manual. If you need questions to what the clutch does or what it feels like, please feel free to ask. I will answer as the best I can. Thanks in a advance.
Re: Need information or pictures of location of tranmission fluid... (Blk_Guy_N_S3DAN)
the transaxle fluid / gear lube is inside the transaxle. One drain plug and one fill level plug. I would think if you did a search you could find more pics and info.
Re: Need information or pictures of location of tranmission fluid... (h22cvcsedan)
Well I searched Transmission Fluid but the information was ish!
Bump..
Bump..
on pass. side there is a drain plug and a fill plug, one is 17mm the other is a 1/2 rachet right behind the pass. tire. there is no transmission bottle, obly whats in the tranny
Re: Need information or pictures of location of tranmission fluid... (SOHCwarrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCwarrior »</TD></TR><TR><TD CLASS="quote">on pass. side there is a drain plug and a fill plug, one is 17mm the other is a 1/2 rachet right behind the pass. tire. there is no transmission bottle, obly whats in the tranny</TD></TR></TABLE>
Got lost reading that.
