cant get the del sol to run
i changed the head gasket on my b16a, and now my car wont run. I thought it was the main relay because the fuel pump wasnt turning on, and i replaced it and that wasnt it. when i tried to start it my window control box fried, and this is were im at now. help....
Re: cant get the del sol to run (b16allmotor)
check the fuse under the hood for the ECU, it should be a 10 or 15, also check the back up fuse, make sure the connections between the car harness and the ECU aare good. You have not by chance replaced the key ignition wiring harness? Sometimes the pins need to be moved around for everything to work, if someone bought one for a different model honda.
the car was running and you changed the head gasket and it wont fire? Is this correct? . It sounds like a ground from the engine to the frame. I had a similar issue with my crx and that what it ended up being.
turn the key to the run position and open the cover of the fuse box, pinch the sides of it and see if you hear the fuel pump prime.
Re: cant get the del sol to run (sans)
i took everything out to take out the fuel pump, i took out the fuel pump and tested it and it works. i checked all the fuses, relays. should i follow all the wires and see if they are mest up.
Check the fuse for the battery and ignition under the hood. Stupid question but is the battery connected tight and connected correctly?
If there is no power to the main relay then there is most likely no power to the ECU , check to see if you are getting power there. I think it is like the last couple of pins on the plug A are 12V constant
Re: cant get the del sol to run (gt30typer)
check the fues labled ACG under the dash. Mine blew one time and I didn't get spark or fuel (I ended up shorting out the circuit one time with a fuel cut off switch)
Re: cant get the del sol to run (asmallsol)
How about where your engine harness grounds to the thermostat housing?
I've seen fuel pumps not work because that ground is off.
I would check your grounds. Make shure they are tight then retrace your steps of pulling the head, fuel lines, electrical connections, you may want to also check EVERY fuse in you fuse boxes, it sounds stupid but maybe you just missed a small connection or ground.
i just went to look for the ACG fuse and there wasnt a fuse there, so i put one in and it blew. does that mean i have a short somewhere.
