P28 ECU problem *urgent*
I just swapped my D15D6 out of my 90 CRX for a D16Z6 out of a 94 Del Sol. I got the OBD1 adapter harness, got it running fine and drove it home. After I start it once and shut it off, it WILL NOT start again and throws code 15 (ignition output) till I reset the ECU. I reset the ECU and it will start and run fine, I shut it off and it wont start again. The P28 was an automatic and I converted it to a manual properly from what I've seen. I've tried removing RP17 and RP18 with a jumper on RP18, and I've also tried RP17 removed with the resistor on RP18. Any way I do it, it still does the same thing. I tried an ECU somebody else had that he had modified taking just RP17 out and the car ran fine and started every time. Anybody know where my issue is?
*edit* My O2 sensor was wired incorrectly for about 3-5 miles of driving before this problem, could my ECU have been damaged?
Modified by ibanender at 5:23 AM 1/5/2005
if your car was running with the o2 wires wrong you should have thrown a CEL. but im not to familiar with the EF's and how they check there codes. But i believe your best bet would to buy a virgin P28 off someone. tampering with Ecu components that ur not familiar or unsure working with can cause problems.
or your Dizzy could be going out soon
Re: (JDMlyfestyle)
What is a Dizzy?
I am using the OBD1 distributer that came on the Z6.
As I said before, the motor runs fine for the 1 run before I reset the ECU and using another ECU it works flawlessly. I am avoiding buying a new ECU at all costs, but I have a feeling the problem lies in the ECU somewhere.
john'sD16Aek
Engine Management and Tuning
01-24-2013 07:59 AM
