swapping
swapping
a jdm b18c goes into a 96 civic dx the same way as a civic 96 ex right? i mean the diff. btwn 1.5 to 1.6 will not make a diff in teh swap as far as the mounts and axels and whatever else is required for the swap goes right?
Mr. Badwrench
Re: swapping (b18c 94)
the wire harness is a little different but it is about the same. you have a 3 wire iac valve you have to convert to a 2 wire valve, just match the 2 wires then terminate the third that isnt used. you wont have to worry about a ckf sensor unless you are goin to be obd2 compliant, but thats a whole nother story.
cheggie
12-15-2011 11:36 AM
justinwazner
26
11-16-2010 06:11 PM
