WHERE IS THE AIR/FUEL ON A P28 ECU
I need to kno whats pin is for air/fuel o2 sensor or w/e on a p28 any1 knows thanks i appreciate it I need this asap
Re: WHERE IS THE AIR/FUEL ON A P28 ECU (Slammed92hbonN20)
IF ANY1 has the lil diagram of the ecu it'll be great and search feature is not workin i kno i seen it before
Here, let me hold your hand:
Top right of page, click "Knowledge Base"
Go to "Search"
Type "Oxygen Sensor"
Or just click this hotlink:
http://info.honda-tech.com/ind...ensor
Go to "Search"
Re: (Slammed92hbonN20)
First what do you need it for? What are you trying to do?
And stop bumping every 5 mins.
Also did you read what DAX wrote? **** i didnt even know that it works like that.
Location: hittin corners so hard you can taste my rims..
just hook it up to anything, cuz as we all know A/F narrowband sensors are a joke.. esspecially when you only get actuall shitty readings in closed loop.
Re: (Built B16A)
if you need this for an air fuel ratio gauge, don't waste your time,
you may as well have you little sister guess a number between 0 and 20, she will be just as accurate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 »</TD></TR><TR><TD CLASS="quote">oh i kno this ***** are way off but i had it since the longuest and **** @ least it kinda lets me kno whats going on </TD></TR></TABLE>
english? and that A/F gauge will only give you accurate readings in closed loop.. idle... or very light throttle. once you go into open loop, it disregaurds the O2 and falls back in the ECU's internal maps.
so... if your thinking that this gauge with pretty lights are gunna tell you how your car is running when you grab 3rd, and hella VTEC kicks in.. im sorry to burst you bubble.
ef9allday
03-22-2013 09:46 PM
shredderkid322
03-31-2011 01:40 PM
ekcivic2
Engine Management and Tuning
06-19-2010 09:59 AM
