Rear Strut Bar that Requires NO Cutting?
As the topic title suggests, I'm looking for a rear strut bar that does_not_require cutting/alteration of the rear panels to fit.
I had my mind set on the PasswordJDM RSB, but after finding out that you have to cut the panel surrounding the rear strut towers, I am back to square one again.
Is there such a bar that would require no cutting? I have a 93 Civic Si hatch, BTW.
Re: Rear Strut Bar that Requires NO Cutting? (doughboy_88)
You're going to have to either cut the panels or remove them. There's no way you can have a bar go from the top of one shock tower to the other without going through that panel.
i have the it-r style rear bar. you need to trim a bit, but if you do it right, the trimming can be covered up by the shock tower covers if you remove the bar later
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">i have the it-r style rear bar. you need to trim a bit, but if you do it right, the trimming can be covered up by the shock tower covers if you remove the bar later</TD></TR></TABLE>
man i tried to order that bar from egay a long time ago, just to try it out and they sent me a front one instead, i was like AW **** it, and just went ahead and threw it away, and bought a spoon rear strut bar. post up a picture of that bar and your cuting u had to do, if u could for this dude.
Vtecin94dx...cool avatar. LOL.
That would be very helpful if you guys post pictures!
I don't want to have to carve up my interior to fit a bar that will likely make a minimal difference.
