gsr motor mount ?
Location: everything for everyone, and nothing for ourselves
Re: gsr motor mount ? (eg6r4eva)
any semi-solid/solid motor mount is going to give considerable vibration throughout the cabin. mine sounds like a low-flying leer jet with just polyurithane inserts.
Re: (maxheat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxheat »</TD></TR><TR><TD CLASS="quote">i dont know about anyone elses.. but mine shakes like a ****..
im gonna save up for hasports </TD></TR></TABLE>
does hasports mounts make the cabin seem like a stock civic ? with no vibrations?
Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">i always thought the hasports would shake more cause the are stiffer, i could be way off though</TD></TR></TABLE>
Correct, I have talked with several people that have had their mounts and they felt like mounts made their car fell like a race car in the cabin. They said the vibration is unbearable. I don't have them myself, but I have heard like 3-4 people that have had them and dislike them. They are good mounts, just has a lot of vibration in the cabin.
Re: (CTRb18c)
I am not sure which ones the people that I have heard from were refering to other than the fact of the brand Hasport. I think with any motor mount inserts or mounts themselves you will get a little more vibration but I have heard that the Hasport ones are just unbearable. I would just put some Energy Suspension motor mount inserts in, that would stiffen up the mounts and keep the motor from rocking as bad.
The stiffer the bushing the more vibration(s). So with that said, ES inserts will have a little more vibration over stock but not nearly as harsh as the Hasport mounts.
God... I love what my hasports do... but my car sounds like its going to fall apart because being rattled apart for 1 year... man...
I do love hem though.
Your stock mount shouldnt make it shake.
Re: (eg6r4eva)
stock mounts should dissipate the most vibration. any mount that does not have a rubber cushion, like the stock mounts, will vibrate the chassis. stock mounts are the best if you can't deal with it.
Re: (eg6r4eva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6r4eva »</TD></TR><TR><TD CLASS="quote">so if i change the rubber mount for a poly would that help cut down the vibration </TD></TR></TABLE>
no the polyurethane bushings are stiffer, therefore making a little more vibration. They aren't as harsh as the Hasport ones though. I would suggest that if you want something to keep the motor from rocking at all. They really aren't that bad!!!
Re: (R33CIVIC)
If you want the motor to feel like stock...replace all your worn/broken mounts with OEM ones.
Anything you do...add inserts, get aftermarket mounts, etc will make it Vibrate, plain and simple.
Re: (sinister2c)
have you or anyone else seen the j's racing engine damper i was thinking that would help cut down the vibration. some insight would help before i go and buy thanks
RacerSi
11-17-2003 02:42 PM
