Window weld to repair trailing arm bushings? or suspension stress?
Re: Window weld to repair trailing arm bushings? or suspension stress? (eric.ws.anderson)
im pretty sure the energy suspension sell s a set of those i have only seen a few people with them but i know they make them. they just press out and then back in.
Re: (eric.ws.anderson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric.ws.anderson »</TD></TR><TR><TD CLASS="quote">they do. I bought the shifter stabalizer bushings and I love them. I'm sure their trailer arm bushings are good too, but I'd like to try the window weld. Can anyone relate any experience to the window weld?</TD></TR></TABLE>
You don't want to use poly on the trailing arm bushing. It's fine for the LCA and other suspension bushings, but poly is too stiff for the trailing arm. The poly can cause suspension bind and bump steer because it won't allow the full range of movement it's designed for.
scratchline20
10
04-30-2003 09:00 PM
