94-95 accord sohc vtec 2.2 into 92 dx hatch?
Old 02-11-2005, 03:42 AM
slammedef06's Avatar
Default 94-95 accord sohc vtec 2.2 into 92 dx hatch?
i have a few questions about swapping in a 94-95 honda accord ex sohc motor into my civic dx hatch. i have included a pic of the motor so there is no confusion. first...
what mounts would i use? h22 mounts?
would i be able to wire the motor to my stock harness? i will have a shop do it.
which axles should i use? i will be going turbo at about 7psi, should i get a stage 2 axel set?
which shift linkage should i use? does it have to be modded?
also, would i save myself a lot of trouble using a the non vtec from the 94-95 accord lx since i wouldn't have to wire up vtec or should i get the vtec?
thanks for any help!
Old 02-11-2005, 05:52 AM
Electrician
Deemeetree's Avatar
You'll need to wire in VTEC. You'll need the OBD-1 ECU if the F22B1 is from 1994 or 1995 or the OBD-2 ECU if the F22B1 is 1996 or 1997. Mounts are from the H22 into a Civic platform. Axles are from the H22 into a Civic platform (which are hybrid). Shift linkage is from the H22 into a Civic platform.
Old 02-11-2005, 06:23 AM
Default Re: (Dimi)
thanks a lot
Old 02-11-2005, 06:44 AM
dantastic's Avatar
F22B1 = 145hp 147 tq
B18B1 = 140 hp 129tq and its soooo much easier.
Old 02-11-2005, 07:08 AM
chameleon's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">F22B1 = 145hp 147 tq
B18B1 = 140 hp 129tq and its soooo much easier.</TD></TR></TABLE>
im with this guy, if your gonna do all that work then might as well drop an H22 in there
Old 02-11-2005, 01:15 PM
Default Re: (chameleon)
i don't think it will be too hard, as long as i get the right stuff. maybe i'll get hasport h22 mounts, hasport h22 axels, have a shop do the wiring. soon after that i plan to turbo it and run like 8 lbs. i should be putting down some decent numbers no? if i do a nice custom turbo kit with a t3-t4, 2.5 inch piping with an apex turbo muffler. 2.5 inch intercooler piping etc. i'm hoping for like 210 hp at the wheels? is that about right with a good tune?
Old 02-13-2005, 08:58 AM
DelSolSi93's Avatar
Default Re: (slammedef06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedef06 &raquo;</TD></TR><TR><TD CLASS="quote">i don't think it will be too hard, as long as i get the right stuff. maybe i'll get hasport h22 mounts, hasport h22 axels, have a shop do the wiring. soon after that i plan to turbo it and run like 8 lbs. i should be putting down some decent numbers no? if i do a nice custom turbo kit with a t3-t4, 2.5 inch piping with an apex turbo muffler. 2.5 inch intercooler piping etc. i'm hoping for like 210 hp at the wheels? is that about right with a good tune?</TD></TR></TABLE>
Dude like they said above if you're doing all that you should just do an H22, you could get pretty much the same horsepower without the turbo if you did an H22 with relatively mild mods
Old 02-13-2005, 09:12 AM
Paulnsx's Avatar
Default Re: (DelSolSi93)
it really is a whole lot harder and more expensive than the b18b. i would def do an ls or gsr swap b4 a f22.... ur gunna have to spend a ton of extra money on the mounts and axles as well as do some modification (cutting a hole in the floor) for the shift linkage. its not worth the hassle for the f22.
Old 02-13-2005, 09:41 AM
McNizzle's Avatar
Default Re: (Paulnsx)
sounds like way to much of a hassle to me. i agree with the others about either swappin the h22 or a b18b. b18b with boost will be easier, more powerful and reliable than the f22 with boost at 7lbs.
colter24
03-02-2009 07:09 PM
sandman1893
11-12-2007 01:00 AM
slammedef06
02-12-2005 06:39 AM
slammedef06
02-10-2005 05:38 AM
J T*
06-03-2003 11:32 AM
Quick Reply: 94-95 accord sohc vtec 2.2 into 92 dx hatch?
