When i turn on my AC and lights, the idle goes far below 1000rpm, like 700 or sumtin..and then my ca
What can i do with this? should i just change the throttle settings or wut its called....or should i buy hyperground wires and battery......maybe its the electricity??
Re: When i turn on my AC and lights, the idle goes far below 1000rpm, like 700 or sumtin..and then m
What car do u have..and if i'm not mistaked idle at 700-800 is normal..
damn my **** idles at like 600 or so all the time after it is warmed up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch34 »</TD></TR><TR><TD CLASS="quote">damn my **** idles at like 600 or so all the time after it is warmed up</TD></TR></TABLE>
and your lights doesnt dim out??
If you idle above 1000rpms normally... You may have a whole nother problem?
its anoyin everytime when its warmed up, when i wanna turn the wheel, the engine turn off...
i heard from sum1 that i had to sumtin with the throttle when i installed an intake...
your ac fan motor may have gone out, mine did and my car wanted to die everytime the ac was on at idle. just check out all of your ac componets, and if all else fails take it out i did... I Love TEXAS SUMMERS !!!
my car idles real low like 5-600 and i have no problems, even with a descently sized system??
i thought that was normal, but ac may have something to do with it, so wouldnt hurt to check out those components
Mine too. Everything is normal and works at it's best. Just low idle.
Got one question (not trying to jack the thread). When I turn my idle screw to make the idle go up, it doesn't do anything? Is that my TPS. If I turn the idle up and down it does nothing. Right now it should be pretty high, but when I touch on the gas it will go down, stay at 900rpm for a sec. then fall back to 500-600rpm. What's wrong?
Andrew14
06-22-2010 09:24 PM
