O2 sensor/air fuel ratio
Old 04-04-2005, 10:04 AM
MinuteRice's Avatar
Default O2 sensor/air fuel ratio
I hooked up an Auto meter Air/fuel ratio gauge, and about two weeks later my check engine light came on. When the CEL came on the a/f gauge stopped working. I disconnected the Gauge and the CEL doesn’t come back on. My question is the gauge bad, is the wiring bad or the O2 sensor bad, or is it something else. I’ve heard that Auto meter A/f gauges aren’t very good. I have it mounted right under my radio, could this be causing some sort of interference?
Old 04-04-2005, 10:12 AM
e jay one's Avatar
Default Re: O2 sensor/air fuel ratio (MinuteRice)
what code was it reading? if your o2 is bad youll be running rich.
Old 04-04-2005, 10:15 AM
MinuteRice's Avatar
Default Re: O2 sensor/air fuel ratio (e jay one)
It threw a fault on primary O2 sensor. after i disconected the gauge i reset the system the CEL is no longer on, and hasn't come back on.
Old 04-04-2005, 11:06 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MinuteRice &raquo;</TD></TR><TR><TD CLASS="quote">I’ve heard that Auto meter A/f gauges aren’t very good.</TD></TR></TABLE>
Then you heard right. Get rid of it, its useless. It'll only tell you if you're above stoich, or below it. Narrowband O2 sensors have a voltage response like a light switch with the trip point being 14.7:1.
Old 04-04-2005, 01:11 PM
WildPig's Avatar
Default Re: O2 sensor/air fuel ratio (EE_Chris)
yeah if you want to have a air/fuel ratio gauge, definately get a wideband o2 sensor system, it'll read what your "actual" ratio is.
And something I've learned in the past few weeks: If you're messing around with wiring then ALWAYS solder your connections! Believe me, it took a week of reseting my ecu over and over until i realized that "pigtailed connections" just arent good enough!
peddyeye
12-01-2008 01:52 AM
johnclaunch
11-26-2007 09:20 PM
Bimmerman
14
05-27-2005 06:45 AM
clutch33
04-08-2004 10:32 AM
97integraLST
11-23-2001 09:16 AM
Quick Reply: O2 sensor/air fuel ratio
