Proper Proportioning Valve
it's a 92 cx( no abs) and my rear disc came off of a integra, i just need to know whats the proper car to take the proportioning valve off of. thanks
Re: Proper Proportioning Valve (oxSLEEPERxo)
3030 - 9.5" front / drum rear
3035 - 9.5" front / larger drum rear
3040 - 9.5 front / disc rear
4040 - 10.25" front / disc rear
4035 - 10.25" front / larger drum rear
(there is also a 3540 that I've seen but I don't know what front brakes it had)
a 3040 would be best for you right now, unless you plan to upgrade your front brakes also, then go for the 4040.
4040 should be from pretty much any 94+ teg with rear disks.
3040 may be from an EX auto (EG or EK) without ABS. but I'm not sure.
Re: Proper Proportioning Valve (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">3030 - 9.5" front / drum rear
Crap, i just installed a 4040 on my 92 CX with 9.5" front rotors and rear drums. I do plan to get rear disc tho. think i'll be ok???
Re: Proper Proportioning Valve (clint g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clint g »</TD></TR><TR><TD CLASS="quote">the one from the 99-00 si work 2</TD></TR></TABLE>
Yes it will but he will have to bend his lines. If he gets one from the 5th gen Si it will be fine, or a teg RS. They all have the same prop valve as his car but the proportioning is different. The 99-00 Si is what you should use for the 6th gen civics.
I am a (Trial User) Army
</TD></TR></TABLE>OMG I don't imagine how that would work. It could, I guess, but that would be the worst install EVAR!
Get a 4040 from any RS non abs teg.
Re: Proper Proportioning Valve (litterbox)
if you can find a ex coupe one then that will work as well. I did a rear disc upgrade on my ex coupe and i used my stock PPV. works fine.
i have a 92eg si nonabs, 9.5 fronts/ rear disc, and it came with 3040, put a 4040 with gsr fronts, yup got a 4040 off a rs non abs94up, ne one need my old 3040, or 1725, from del sol dohc
Re: Proper Proportioning Valve (sic my duc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sic my duc »</TD></TR><TR><TD CLASS="quote"> ne one need my old 3040</TD></TR></TABLE>
hey man i really could use it, how much?
you should have a 3030, you can check on the firewall, you would need a 3040 off a 92-95 civic si non abs,and a del sol si, without b16 and abs should work too. thats only if you have 9.5 fronts,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">what proportion valve is in my car, and what car the valve i need is in?</TD></TR></TABLE>
thats my reply to sleeper, still gettin used to this,
Re: (_OEM_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _OEM_ »</TD></TR><TR><TD CLASS="quote">couldn't you just use a MC from a 91 ex sedan (4 wheel discs) and be done with it? someone correct me if i'm wrong. </TD></TR></TABLE>
you still would have to upgrade the prop.valve to give the right pressure to the rear disc upgrade.
littleblue
08-24-2009 12:20 PM
BlueTeg
08-29-2005 09:01 AM
BlueTeg
11
08-25-2005 10:43 PM
spoolinq
10
07-28-2005 08:54 PM
