srs airbag light on
srs airbag light on
so i took my interior out of my eg to trade it with a black interior i put everything back and know my srs light is on, so i checked the airbag connections and they were fine, i disconnected the ecu battery and the back up fuse , still nothing. can anyone tell me what i missed?
Re: srs airbag light on (Bcuz)
When the "Search" server becomes available again, search the topic, there was a few really good write ups that show you how to reset it with pictures. It took me a couple tries, but eventually I got mine reset. Or else you could try to google it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz »</TD></TR><TR><TD CLASS="quote">I'm guessing along with everything else you took out, the seats or atleast tampered with there connectors, try that and good luck.</TD></TR></TABLE> iI just checked the seats my driver side is connected but I don't see a connection for the passenger seat and i don't remember disconnecting it, does the passenger have a connection also?
Re: srs airbag light on (h kid)
You only have one connector under the driver seat, none under the passenger seat.....But im pretty sure that all that connector for is for the seat belt light, i dont think that has anything to do with your srs light..Goodluck with your problem (my srs light is on but i just disconnected it from teh back of my cluster, haha)
You need to reset the SRS computer.
DIRECTIONS: There is a little yellow connector on fuse box. Take it and seperate it from the fuse panel under the dash. Take a paperclip and bend it to hook into the holes. Do this while the car is OFF. Turn the car on the SRS should be ON. When the light goes out remove the paperclip. As soon as the light comes back on put the paperclip back in. Keep doing this until the SRS light flashes and shuts OFF. This will reset the airbag system.
Hope this helps. I had to do the same thing in mine. Oh yea check your horn if it is not working either than the cable reel broke and you will have to replace it and reset the SRS. If you have anymore questions on airbag stuff send me a message and I'll help with anything I can. Good luck.
Re: srs airbag light on (tabrisakakaoru)
there is two yellow connectors in the fuse box is it the one on the top or the on on the bottom right that looks like a dummy plug does anyone know
Re: srs airbag light on (CfS2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CfS2000 »</TD></TR><TR><TD CLASS="quote"> (my srs light is on but i just disconnected it from teh back of my cluster, haha) </TD></TR></TABLE>
That's really smart, so when you get in an accident your air bag wont deploy. Or wait... NO.
Re: srs airbag light on (SRCivic97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 »</TD></TR><TR><TD CLASS="quote">
My car doesnt have airbags
</TD></TR></TABLE>yeah buddy my air bags are removed
Re: srs airbag light on (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">
My car doesnt have airbags </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CfS2000 »</TD></TR><TR><TD CLASS="quote">yeah buddy my air bags are removed</TD></TR></TABLE>
It makes your car faster y0!
I hope someone notifies your insurance company and they dump your coverage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">i dont think u have to have airbags to have insurance....</TD></TR></TABLE>
No, but removing airbags and the SRS system from a car equipped with one is a problem.
O.G. triple O.G.
This thread was from a fellow HT member:
Directions for erasing memory on SRS light
1st you need to either buy or make the "SCS Service Connector." I used a speaker harness for and older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly.
2nd you need to find the MES (Memory Erase Signal) connector which is pictured below: (Click to enlarge)
MES Plug in Fuse box.
**pictures removed at source**
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">
I hope someone notifies your insurance company and they dump your coverage. </TD></TR></TABLE>
It makes your car faster y0!</TD></TR></TABLE>
no need to be smartasses.......my car was in an accident and they deployed, but i have a new steering wheel cover(where the air bag comes out of) and i passed inspection and insuance company knows thanks!
