Installing a stereo in an 01 civic RIGHT NOW.. need help
1 Post
Like it says, Im doing a stereo in an 01 civic...... I've done a lot of 96-00s...... but never an 01. Where should I start in order to get to the center bezel?
Re: Installing a stereo in an 01 civic RIGHT NOW.. need help (D50boy)
Found on google:
"01 civic is easy. You pop off the panel that the cigarette lighter is in, and then use a socket and remove the two 8mm screws. Then put your hands on the back of the bracket the readio is attached to and push the radio and the whole panel out of the dash. If you try to pry the radio assembly/panel out then you will leave marks on the dashboard.
If you buy a dashkit for the car, it should have instructions for removal, and reassembly."
JackRabbit
11-07-2008 11:33 AM
