CEL HELP!!
CEL HELP!!
ok as i have posted in this thread about my prob. about my ITR manifold idle problem..that we fixed i now have ANOTHER problem...the problem last time was the TPS sensor loose NOW the idle will stay at 2k and i have screwed in the idle screw all the way in...and i have a CEL which is !....!....!!!! which is 24 but i dont see any 24's on the ECU threads..could anyone help??
Re: CEL HELP!! (1TwistedEG)
Sounds like your throwing 2 codes over that 1 that you think.
I think your throwing 1 and 14 which makes alot of sense to this thread:
1 O2A - Oxygen sensor #1
14 IAC (EACV) - idle air control valve
Check your IACV, and also clean out your FITV and your idle should be fine.
Colorado <3
dont mouth newb.. You would have never had to make this thread if you knew how to check your cel's IACV just a search.. There is over 20 topics for it.. https://honda-tech.com/search
Colorado <3
Re: (1TwistedEG)
918 - shut the **** up, you have your own problems to deal with. I dont think you want people to come into your VAFC thread that you bump every 15 seconds just to tell you to search.
Heres how to fix the FITV
https://honda-tech.com/zerothread?id=699787
For the IACV, just take it off and spray it with carb cleaner and that should help you provided it worked before.
thx luserkid i apriciate the help and 918 thx for bein an *** but also thx for postin up that link..it woulda saved u a flame job if u woulda just posted the link up first instead bein a comlete *** hat..
