transmission problem. Help !
Old 10-11-2013, 05:05 PM
zcmotor's Avatar
Default transmission problem. Help !
I have a 98 honda civic lx auto
yesterday it was just reving up and wouldnt go nowhere
when its in drive it takes about 5 secs for it
to start rolling but I have to give it gas
I have code p0700 anf p0730
does it mean I have a bad tranny ?
Old 10-11-2013, 05:25 PM
TripleLude's Avatar
Default Re: transmission problem. Help !
I don't know what the codes mean, but maybe you should check the fluid. Only use Genuine Honda ATF in there.
If the fluid is good, you might need a torque converter. Lucky for you it is a Honda, so pull it back to 2nd when you need to get rolling. Just remember to put it in drive on time. I had to do that on my first ever Honda: a 1984 Accord. It worked for about a year, then I bought a Prelude and sold the 84 Accord for cheap.
Old 10-11-2013, 05:30 PM
zcmotor's Avatar
What kibd of trans fluid is it ? I bought a quart from autozone
that must of caused the prob
Old 10-11-2013, 05:40 PM
jbpnoman's Avatar
No, it's not a fluid problem, no, it's not a torque converter problem. P0730 points specifically to your clutch pressure system. You can either get a FSM and follow the procedure for diagnosing and fixing it, or you can give me some time to find mine and find the procedure.
Old 10-11-2013, 06:14 PM
zcmotor's Avatar
Its a automatic. Reverse works fine
Old 10-11-2013, 06:45 PM
zcmotor's Avatar
Icon3 Re: transmission problem. Help !
Someone told me its the transmission
shift selonoid
Old 10-11-2013, 08:00 PM
jbpnoman's Avatar
The solenoids are part of the clutch pressure system, yes.
da35apprentice
04-03-2017 08:42 AM
hellah fresh
11-27-2012 06:01 AM
licks
05-09-2010 04:24 PM
mjmont
06-13-2007 04:20 PM
teler86
10-16-2005 11:19 AM
Quick Reply: transmission problem. Help !
