How-To: Alternator Tensioner - D16y's Finally!
FYI, it is a 2000 Civic EX with D16y8 head and D16y5 block.
I got tired of manually tensioning the alternator belt alone, so I made this thinger from scraps and an eye-bolt from Tractor Supply. As you can see, I bench-tested the strength and then added some angled aluminum to reinforce the steel bracket.
Used:
- eye-bolt for 150lbs.
- fiber reinforced fuel line.
- silicon tubing for mounting eye-bolt to alternator.
- metric 10mmx1.5 bolt for mounting eye-bolt to alternator.
- extra washers.
- used copper crush washers around fuel line to brace bracket.
- zinc-dipped grade nut for eye-bolt.
- grade 10 nylon lock-nut.
- angle aluminum.
- Mobile1 synthetic grease for the tube and fuel line.
Untensioned on bench:
Tensioned on bench:
Installed on car, without belt:
Parts used:
Angle aluminum installed for extra support:
Remember, this tensioner is only used to enable the initial tension. Then tighten the mounting bolts to hold the tension. This device isn't really intended to support the belt tension long-term.
Used:
- extra washers.
- angle aluminum.
Tensioned on bench:
Parts used:
Fix_it_Yo_Self
08-02-2017 12:03 PM
