Odd knocking noise.... Any ideas appreciated..
Old 10-13-2013, 09:32 AM
john159753's Avatar
Default Odd knocking noise.... Any ideas appreciated..
This is not my car, but i am really making a post for my brother. His engine (B18C Type-r) has out of the blue started making this knock. It sounds like the knock is coming for the top of the motor.
He tried adjusting the valves (which were off) but that did nothing. Today he was messing around and unplugged the map(I have no idea why..). I know that when you unplug the map the car runs like ****, but it still runs. And with the MAP disconnected, the knock was gone. Obviously when we restarted the car the knock reappeared. So that royally confuses me. If you guys have any ideas to what it could be, it would really help us out.
I have a video here, hopefully it works. if it doesn't, let me know.
https://dl.dropboxusercontent.com/u/...2018.29.58.mp4
Thanks tons
-John
EDIT: Car runs perfectly fine, but common sense tells me that running a car with a noise like this cant be good.
Old 10-15-2013, 08:10 PM
VTECn83's Avatar
Default Re: Odd knocking noise.... Any ideas appreciated..
Is the timing off?
Old 10-15-2013, 11:51 PM
Solster's Avatar
sounds like a Rod but as you say it's up top make me think cracked piston. depending on the crack you can have good compresion and still be cracked.
http://www.autozone.com/autozone/rep...btitle=inspect
Cracked pistons are often the source of noise.
The noise is sometimes higher pitched than a crank related noise and could be confused with a valve train noise.
Cracked pistons are often the result of a broken timing chain or improper valve timing, which can allow a valve to strike a piston on some engines.
Old 10-16-2013, 07:34 AM
john159753's Avatar
Thanks Guys. Timing should be dead on. Guess the only way to know is to open it up and see whats going on..
Old 10-16-2013, 08:15 AM
purgat0ry's Avatar
Get a stethoscope and isolate it to specific cylinders.
Do you have any CEL's?
There was recently a post about faulty/old/shitty LMA's, dig that up and read through it, it may yield some results
Wannabe JDM
06-01-2013 08:30 PM
PerfectionIsKey
01-28-2013 09:53 AM
acracer2008
08-02-2010 05:35 AM
ludeboi121
04-26-2007 08:12 AM
vx3
03-30-2007 02:58 PM
Quick Reply: Odd knocking noise.... Any ideas appreciated..
