head lights
Re: head lights
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-how-aim-your-1992-2000-headlights-2086368/
Okay, I'm posting this up here because I see it posted SO OFTEN!
So, hopefully this (I'll ask that it be put into the FAQ) will help cut down on so many threads about it. I've also been sure to add a number of keywords at the bottom so it will be easier to search for as long as you search for the post content.
This information should be in your Honda Owner's Manual.
This is from the service manual, but from looking at my owner's manual, the information is basically the same. 5G owners might want to look at the 6G directions too, since the 6G directions go much more in depth about how to properly line up your lights. The 5G directions only tell how to move the lights.
Supplies:
- Measuring tape
- Paper, pencil and tape (if you don't want to write on the wall or the wall is too dark)
- Phillips tip screw driver
- Level ground with a wall
You might also want to check your tire pressure beforehand and unload anything that you don't normally drive with. Putting someone approximately your weight in the driver's seat will also help to make it as perfect as possible by hand.
Here are the directions for the 1996 to 2000 Civics.
Here are the directions for the 1992 to 1995 Civics.
And more help for how to actually line them up properly.
http://www.automedia.com/Aimin...1ha/1
Aiming Headlights
Or, how to maximize visibility without blinding other drivers
Tom Morr / autoMedia.com
How many times have we all been blinded by an oncoming vehicle and flickered our high beams, only to have the other driver melt our corneas by responding with their brights? The conclusion: Those low beams are jacked up (both literally and figuratively).
Causes
Headlights can become misaligned in many ways. One of the most common is when the person replacing a bad light inadvertently turns the adjusting screws instead of the retaining fasteners. Fender-benders and other front-end damage can also cause lights to become askew, as can carrying heavy loads in the rear quarters (which is why several upscale SUVs now have automatic load-leveling suspension systems).
Many repair shops will check and adjust headlights for a modest fee. However, the process is straightforward enough that the average do-it-yourselfer can save both time and money by following the steps shown here. Although special products are made specifically for correct headlight aiming, the method here doesn't require any proprietary know-how or materials—just masking tape, a tape measure and a screwdriver. Incidentally, most repair manuals recommend checking headlight adjustment every 12 months and any time a lamp is replaced or front-end damage occurs.
Begin by finding a level surface and a vertical garage door or wall. Park the vehicle close to the wall and mark the lights' horizontal centerlines with masking tape.
Next, mark the low beams' vertical centerlines. For better precision, stand behind the car at its center point and, looking through the back window, guide a helper in marking vertical dead center. Marking the vehicle's centerline is also helpful to verify side-to-side alignment.
Park the vehicle on a flat surface 25 feet away from the wall, pointing straight ahead. Use the lights' horizontal- and vertical-adjusting screws to position the low beams' intensity zones two inches below and to the right of the taped centerlines. (Trim ring removed to show adjusters.)
Adjustments can normally be made without removing any parts. Turning the top adjusting screw clockwise raises the beam and vice versa. Similarly, the side adjuster moves the beam left and right.
High beams' "zones" should be below the line and vertically centered in relation to the vehicle's centerline (not marked with tape in this example). Here, the right-side high beam needs to come inboard. When in doubt, be courteous and err your aim low and to the right.[/I]
Copyright autoMedia.com 2000-2007
More links that might help:
http://www.ehow.com/how_3383_a....html
http://www.diynetwork.com/diy/....html
http://www.carinsurance.com/Ar....aspx
http://news.carjunky.com/how_s...shtml
Search Keywords:
headlight headlights headlite headlites head light lights lite lites adjust adjus adjuss adjusted adjusting aim aimed aiming right left vertical horizontal indicator gear screw screwdriver driver passenger up down left right 1992 1993 1994 1995 1996 1997 1998 1999 2000 92 93 94 95 96 97 98 99 00 '92 '93 '94 '95 '96 '97 '98 '99 '00
Supplies:
- Measuring tape
Aiming Headlights
Causes
Search Keywords:
NOFX
29
02-01-2015 11:17 PM
B2FiNiTY
11-13-2001 01:58 PM
