Speedometer issues....
Old 10-13-2013, 05:40 PM
MikesEJ1's Avatar
Default Speedometer issues....
i just bought a hooptie,a 93 civic lx sedan auto as a daily,because my ej(recently painted)is getting all dinged and scratched.back to my problems,the speedometer was all over place when it did work and the check engine light was on,pulled the code #17 for VSS,so i changed the speed sensor.now it works and doesn't work.no more check engine light tough
my question is could it be the cluster? if i bang on the dash it will start working again,also sometimes the dash lights go out
has anyone had their cluster go bad on their eg's?
Old 10-13-2013, 06:08 PM
Former User's Avatar
Default Re: Speedometer issues....
Corroded terminals in the VSS plug is a common problem.
Old 10-13-2013, 06:13 PM
MikesEJ1's Avatar
hmm i'l have to check that and get some dielectric grease,thanks
Old 10-13-2013, 06:42 PM
zachhthe1's Avatar
I've had that issue after a tranny swap and clutch upgrade. It would go haywire. Your odometer won't turnover if the needle totally stops if your having the same prob. If it's not corrosion you can try cleaning the actual sensor. After I did that my speedo works all time now. Just a thought.
Old 10-14-2013, 08:00 AM
MikesEJ1's Avatar
yes I noticed this,the odometer shows almost 162,000 miles...I dont know how long the car had VSS problems,soo that means it may have alot more miles on it right?
Old 10-14-2013, 06:38 PM
TomCurllyFry's Avatar
I had the same problem the clip connected to the vss typically goes bad I went to junkyard and cut a clip and put a new one it worked awesome eversince
Old 10-17-2013, 07:51 AM
JWFokker's Avatar
I haven't investigated it myself, because my VSS is somewhat loose in the transmission, but I've read that the gauge cluster may have some solder points that need to be reflowed and causes the same symptoms because contact is intermittent or just not good enough.
Old 10-28-2013, 06:24 AM
Capt Duck's Avatar
I had the same issue. finally one day when i was at the junkyard. I decided to pull out a speedometer from another civic. I brought it home and verified all the solder points were good. I just swapped out the board on the back of my speedometer and have never looked back. I have no more issues with my speedometer. It is worth a try. And the speddometer only cost me 5 bucks.
_EF9
04-21-2013 09:59 AM
curtie94
02-21-2012 11:47 AM
Rafaelmalp19
08-20-2010 10:52 AM
TheShallot
12-16-2008 09:05 PM
mmurphy
03-24-2006 10:07 AM
Quick Reply: Speedometer issues....
