b16a2 throttle body question
Mr. Badwrench
Re: b16a2 throttle body question (speedracer001)
if you are looking for a bigger t.b. bore yours and save the 180 to spend elsewhere. i dont think you will see that much of a gain especially with a stock intake. but thats my o.o2 i could be wrong.
Re: b16a2 throttle body question (boostedcivicsir)
don't mean to jack or anything, but do you know how to bore a tb? is it something you can do with a drill press, or bring it in to a machine shop? cost?
well i did drop in a set of cams...a stock throttle body for a b16 is about 58mm. I have upgraded to a 65mm. Is it too big and should i trade for a type r
Mr. Badwrench
Re: (speedracer001)
get a manifold to compliment yout throttle body. like a type r or blox or skunk.
and to bore a t.b. you need a machine like a bridgeport and you need a lathe to put the correct bevel on the throttle blade.
look at http://www.maxbore.com for info on boring throttle bodies.
Re: (speedracer001)
it depends how crazy you want to get, if you want a street car, type r is the best, port the head, cams valve springs retainers, at least 30 hp increase.
Re: (93b16CivicSi)
65 is pretty big, on my h22 its 62 and that was a "big" tb. however, more air doesnt really turn muc difference unless you are supplying more fuel or have the valve train to support it. you have to work from both ends.
