urgent: Cluster light problem.
ok im at a friends about to drive back and its MAD dark, my cluster won't light-up but my headlights do, turn signals (the signals AND the dash indicators) light up nicely, everything seems to work.
i need this for ease of driving home
car: STOCK 1992 civic VX hatch
what i need to know: im going to start with checking the fuses, which fuse(s) controls the cluster light?
also... in the even that the fuse is fine....what else could this be caused by?
ANY help would be greatly appreciated.
Re: (TenLarge)
I would check your dimmer switch. I have heard of them going bad and it cuts power to the cluster lights. Take a voltmeter and check to see if the dimmer is working.
Re: (Bond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">I would check your dimmer switch. I have heard of them going bad and it cuts power to the cluster lights. Take a voltmeter and check to see if the dimmer is working.</TD></TR></TABLE>
^^^^Just do this first. Yes you can bypass the dimmer and it will always be on high. I never touch my dimmer so it's always on high.
alex22
03-17-2010 02:55 PM
Slvr_CRX
10
07-12-2005 12:06 PM
