Crank pulley bolt..........
http://buy1.snapon.com/catalog...talog
Would the above mentioned gun work in removing the crank pulley bolt with no problems?
Electrician
You should always have some sort of way of locking the crank in place so it won't turn. A big gun and a crank pulley locker would do the trick in 2 seconds.
http://buy1.snapon.com/catalog...store
At the above mentioned URL there are a few other 3/4" guns with more torque than the one I put in the first post. Would the other ones be a better choice?
Re: (Noct)
that 1 you put in the other post should do it......i have got theme off before with a plug in impact gun ..so you dont really need nothing super pwerful and expensive
Re: (tthumma10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00mofo »</TD></TR><TR><TD CLASS="quote">when i did and it probably took about less than 5 minutes to do ..
1) take the boot off not all the way just to see the hole where the slave cylinder goes in(one on transmission)
2) stick a flat head screw driver through the hole
3)try and find the holes in the fly wheel and stick the screw driver in there
4) get someone to hold the screw driver for about 3 mins
5) brake the crank pulley bolt
6) your home free
tools used were breaker bar, flat head screw driver and socket for crank pulley bolt
6) your home free
Re: (00mofo)
DO NOT STICK A SCREW DRIVER IN THE FLYWHEEL TO HOLD IT. That is one of the dumbest things I see people do instead of renting the tool to hold the pully properly. Its just worth the risk of damging the flywheel and or transmission housing. Get the tool and get the airgun, You'll use it later for other things on the car aka suspension for example.
HT Order of Merit
Re: (00mofo)
Ive had to take mine off a few times. Impact gun works well, but dont sit on it. Do it in spurts, it will come off.
Oh and I used a $25 90lb 3/4" impact gun from autozone.
bradley
13
01-09-2012 02:12 PM
