Need help, I wanna paint my valve cover...
And i was wondering if it was as easy as unscrewing the nuts that I pointed out. Is it easy to replace or is there things I should be careful with?
Electrician
Remove spark plugs.
Remove hose on upper left hand side.
Remove nuts.
Pull out.
When you put it back, be careful to seat the o-rings that sit on top of the "ports" where the spark plugs go. Plus, careful on how the seal around the valve cover seats and make sure it's clean. Also, don't over-tighten the nuts when you put it back on, they will break EASILY. Last thing, clog all holes with paper towel or paper, try not to get paint INSIDE the valve cover.
Remove nuts.
Pull out.
Re: (H.crx-si)
you should replace the valve cover gasket and the spark plug seals anyways because they are cheap....sometimes just loosening the nuts will break the bolts, they are very week, but easy to replace
Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">Remove spark plugs.
Remove nuts.
Pull out.
When you put it back, be careful to seat the o-rings that sit on top of the "ports" where the spark plugs go. Plus, careful on how the seal around the valve cover seats and make sure it's clean. Also, don't over-tighten the nuts when you put it back on, they will break EASILY. Last thing, clog all holes with paper towel or paper, try not to get paint INSIDE the valve cover.</TD></TR></TABLE>
even tho it's common sense, you don't have to remove the plugs, just the wires...and i'm sure it's just a typo there
when you put them back on, remember to torque them down to spec(84 in-lbs if i remember correctly)
Remove nuts.
Pull out.
PunkRudeBoy
12
05-05-2018 09:04 PM
standbackimapro
04-29-2006 05:38 PM
standbackimapro
12-16-2005 11:07 AM
