B20b/z question, I've searched to no avail...
Re: B20b/z question, I've searched to no avail... (zerovandez)
swap the intake manifold to a ls and are you going to boosted it others wise the sleves are ok
trans axles ls ecu ls intake manifold shift linkage mounts
If I get you correct u just want to swap the B20 unmolested in your teg...correct? The rad hose should be used from the chassis that engine came out of.. But the B20 should be damn close to that of the B18a/b engines. Only reason you'll need an intake, is because the intake on the B20 in CRV's are very vertical and probably wouldnt fit under your hood line. The trany needs swapped cause of AWD tranny that would come w/ the B20 from the CRV.
Darton makes sleeves for the B20. Golden Eagle makes stuff fof that engine also.
Absubtle
PA
Absubtle
Pa
Absubtle
PA
Absubtle
Pa
