LSD transmission
Re: LSD transmission (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Eat tires? I've never once heard of an LSD transmission being hard on tires. </TD></TR></TABLE>
Actually.. I think the original question should be when the LSD is super aggressive.. will it be hard on tyres..i have been driving in some nasty places..with a 2 way.. hell the tyres spin and **** and causing a lot of rubber to be gone on the road..
now im back with a stock lsd...
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: LSD transmission (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I think bad camber will eat your tires faster than an LSD tranny. </TD></TR></TABLE>
camber does not eat tires, excessive toe does. and a oem lsd will have no effect on tire wear either.
1 Post
Re: LSD transmission (JDMOrangeFever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMOrangeFever »</TD></TR><TR><TD CLASS="quote">Toe is the worst for tire wear.. but camber still eats up inner tires..</TD></TR></TABLE>
if you had 0 toe and 5 degrees neg camber and was burning out everywhere, then yes....
Re: LSD transmission (91crex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91crex »</TD></TR><TR><TD CLASS="quote">does having a LSD tranny eat tire like crazy or is that just people tlkin poo?</TD></TR></TABLE>
I had a JDM b16 tranny with LSD and it had no negative effects that I noticed on my tires, after 6 months of owning that car with the LSD tranny there was no more then normal wear on tires.
lsd isn't hard on tires unless you have 300-600 whp and can't keep you foot out.
unless of course the diff stays locked then I could see where it would be harder on tires but that would be part failure and you would know because you couldn't turn w/o screaming tires.
Re: LSD transmission (civicpacrat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicpacrat »</TD></TR><TR><TD CLASS="quote">lsd isn't hard on tires unless you have 300-600 whp and can't keep you foot out.
unless of course the diff stays locked then I could see where it would be harder on tires but that would be part failure and you would know because you couldn't turn w/o screaming tires.</TD></TR></TABLE>
huh????
huh????
Global Moderator
wtf did you just say?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMOrangeFever »</TD></TR><TR><TD CLASS="quote">Toe is the worst for tire wear.. but camber still eats up inner tires..</TD></TR></TABLE>Camber causes un-even tread wear.
Re: LSD transmission (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">
I think what he meant is that if it's locked, you're fucked (especially on FWD). Think about the car turning around in a full circle with the wheels cranked in one direction the whole time. The inside tire will turn slower than the outside tire, or will travel less. If the diff is locked for some reason (failure I guess) it'll try and spin the inside tire at the same speed as the outside tire and cause hopping and make the tires squeal. If anyone here has ever driven an old Jeep, they know exactly what I'm talking about.
Re: LSD transmission (CycloneBlue_1.6EL)
But arent we talking about a working LSD?
left and right tyre will be unevenly wear in hard driving.. slippery surface to be exact.
If you have a LSD, try drive it in rainny day, go thru pot of water in one of your front tyres.. you will know why its eattin up lots of rubber..
EG6sir2seb
14
07-30-2007 05:20 PM
madmanmulligan
02-03-2006 10:47 PM
CaliforniaHighwayPatrol
47
07-25-2005 08:12 AM
