low oil pressure!!?? HELP!!
I recently changed my oil pan, and after about 25 minutes of driving (easy driving, didn't even rev past 3k) my oil light comes on when at idle.
-oil is good, right below the second hole on the dip stock
-pan is not dented
-pickup is clean and not dented
-oil pressure gauge (mechanical) shows no/little pressure at idle
could it be a coincedence that my pump went bad 25 minutes after i changed my pan?
Can anyone suggest what i can check or what the problem could be!! i'm getting desperate!!
-pan is not dented
Re: low oil pressure!!?? HELP!! (Archidictus)
i was sorta thinking that's what it could be, but it's just sorta wierd how it happened right after i changed the oil pan. i haven't started my car after that except for 5 seconds to test the pressure with the gauge.
Re: low oil pressure!!?? HELP!! (x O 16581 72452 5 x)
there weren't any grey swirls, just looked like regular oil. any other possibilities? i just wonna make sure it's the pump before i spend the money on a new one. thanks!
Re: low oil pressure!!?? HELP!! (stockgreencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockgreencivic »</TD></TR><TR><TD CLASS="quote">there weren't any grey swirls, just looked like regular oil. any other possibilities? i just wonna make sure it's the pump before i spend the money on a new one. thanks!</TD></TR></TABLE>
Did you have the oil pick-up off of it when the oil pan was off?
Re: low oil pressure!!?? HELP!! (Chiovnidca)
Check your sump screen, make sure it's clean, i'd assume you've been changing your oil filter after every oil change or atleast every other.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Did you have the oil pick-up off of it when the oil pan was off?</TD></TR></TABLE>
i only took the oil pick-up off when i started having problems because i thought it may be plugged or something - which it wasn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x O 16581 72452 5 x »</TD></TR><TR><TD CLASS="quote">Check your sump screen, make sure it's clean, i'd assume you've been changing your oil filter after every oil change or atleast every other.</TD></TR></TABLE>
i checked the pick-up screen. it's clean - nothing is on it. oil filter was changed about 200 miles ago.
Is this problem pointing to a faulty oil pump??? or something else that I can check??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockgreencivic »</TD></TR><TR><TD CLASS="quote">i only took the oil pick-up off when i started having problems because i thought it may be plugged or something - which it wasn't.</TD></TR></TABLE>
Did you replace the gasket on it? Was the oil pressure a preexisting problem?
Did you replace the gasket on it? Was the oil pressure a preexisting problem?</TD></TR></TABLE>
i never replaced the gasket, but the inside of the gasket was clean and oil free (seemed like it sealed ok). i never took off the oil pick up before i had this problem, so the gasket should be ok. This is a new problem, never had an problems like this before.
singledoodle
11-24-2016 02:12 PM
