pulley question
pulley question
i just got a aem pulley set and a unorthodox racing crank pulley an im bout to put it on an my question is will there be and timing adjustments needed?
Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">Yes, definitely check that the crank and cam are both set to TDC before you tighten anything up.
Darth ModerVader
Re: pulley question (civicek00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicek00 »</TD></TR><TR><TD CLASS="quote">i just got a aem pulley set and a unorthodox racing crank pulley an im bout to put it on an my question is will there be and timing adjustments needed? </TD></TR></TABLE>
Assuming you're just removing the old pulley and replacing it with the UR piece, neither the cam nor the static ignition timing will change. Therefore, if it was fine before the installation, there's no need to check or adjust the timing once the UR piece is installed.
As for the AEM pulleys, I personally wouldn't suggest running them with the UR crank pulley since both are intended to under-drive the accessories, so you might just want to consider selling or returning them and putting the money towards another modification.
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicek00 »</TD></TR><TR><TD CLASS="quote">why is it a bad idea to use both?</TD></TR></TABLE>
I don't suggest it because unless you're running one of UR's stock diameter pulleys, you will essentially be "double under-driving" your accessories by running the UR pulley in combination with the AEM pulleys. The AEM pulleys aren't terribly effective anyway, nor are they extremely easy to install, so that's why I recommended that you either return or sell them and put the money towards something else.
Re: pulley question (Padawan)
i got the ultra s pulleys from UR. the store told me it was ok to run both of them therefor i bought both of them... will it do any harm???
Darth ModerVader
It sounds as if the store was trying to get you to spend as much money as possible. As I said, I wouldn't recommend running both because of the large degree of under-driving that will result.
blue_hatch
09-07-2007 10:38 AM
