Turbo Si 00.. which ECU i need
hi.. im currently running a t3t4 turbo on my civic si 00 rite now... i was wondering is there any ECU i can use... i try looking up Hondata... but there isnt any for my car unless i have to change my OBD2 into a OBD1... that for sure i will not pass the inspection... can anyone tell me which ECU out there i can use... thanks
Re: Turbo Si 00.. which ECU i need (thangnhocngheo)
your car can pass inspection with turbo?
edit: Try looking up information using the search feature or check out the Forced Induction forum. (not being mean)
Re: Turbo Si 00.. which ECU i need (Advan06)
yes... NC doesnt have that much of restriction here... as long ur check engine light is not on... and everything works... thats about it... i kno that CA has this smog check **** goin on... but yea... i had my turbo on and i was doin inspection 1 time and they pass me...
Unceasing Measure
You need some sort of tuneable computer to run your setup correctly. Try looking into local Uberdata tuners who can chip your stock ECU and tune from there.
Re: Turbo Si 00.. which ECU i need (Archidictus)
I don't think you can chip the stock ecu on a 00 Si (OBD2b). I am pretty sure you can only chip OBD1 and prior ECUs. You would also have to convert to OBD1 to use uberdata, just like with the Hondata. The only plug and play is the AEM EMS.
Re: Turbo Si 00.. which ECU i need (00TurboEX)
if you wanted to convert to OBD1, the ecu of choice would be the P28 with uberdata. the reason being is because there are countless P28s out there and uberdata is FREE! we all like free
so basically i cant change the ECU and have a my OBD2.... unless i change a OB2 into a OBD1 then i can change my ECU.... damn this sucks.... but i heard some say that VAFC works somehow.. is that rite?
it's called a VAFC hack. those are not any good if you want to run "good" boost. the only way to go is to have a stand alone fuel management system.
Honda-Tech Platinum Member
vafc works fine for some people... if you search the archives you'll come across a bunch of people against it on an FI car. You;re from NC, most ppl would want to be in your place where emission isn't a problem. Convert to OBD1, you'll get much better and safer results.
you can go with an AEM Plug & Play Programmable EMS, they are a little pricey at 999.00 but its an option
grammer nawzi
Run the obd2 to obd1 harness any other day, when you go to get inspected just pull it out and put in your stock ecu.
Re: Turbo Si 00.. which ECU i need (screwballz)
yea... i think thats the only way... swaping out whenever i get it inspect... thanks alot guys.... oh yea... my sn is in vietnamese... its not a name... well thanks alot guys... preciate ur opinion
