Melted my ground vtec solenoid wire??????????
Location: With my POS D15B2, Whereever whenever, United States
Well, I kept pulling a 41 code, so I wired up the 3 wires directly to the ecu, with the exception of the green wire, which was suppose to be a ground.
After grounding it, I still got the code, so I wired it up to the green white map sensor like indicated.
I connected only one map sensor and disconnnected the other map sensor.
The car kept cranking over and over, until i saw smoke and stopped LOL.
so going through the entire harness, WHAT A MESS, I saw that my ground for the vtec solenoid melted.
Anyways, I'm just curious what happened,
pics to come
pics to come
Re: Melted my ground vtec solenoid wire?????????? (stingray2772)
melted in the main harness by the motor
Re: Melted my ground vtec solenoid wire?????????? (MugenHonda)
If you can see the copper, thats the wire i melted, and it connected right to the vtec solenoid.
While it melted, one of my map sensors, the firewall one was unplugged and i had my green o2 sensor wire connected to the green/white wire which is the wire in the middle of the map sensor.
Here is proof that i have 2 map sensors
the map sensor on the firewall is wired in the main harness around the shock tower
Re: Melted my ground vtec solenoid wire?????????? (Advan06)
lol, I'm just lucky it was only that one wire that shorted, hopefully i didn't short my p28 and i'll drive around with the stupid code 41 cell, i really don't care anymore, after experiencing it
what is that second Map on the firewall doing??? It is supposed to measure Manifold Absolute Pressure? I dont see anything(vaccum line,etc) connected to that Map sensor. Was this car ever turboed because I always thought that you only had one MAP sensor. MAybe I read your post wrong or something. If you trace the wires to the ECU do they connect at the same location as the other Map sensor. If it does then chop it off leavign some wire incase you need to reconnect it for some reason. But if there are two of these then removing one should solve your problem.
Re: Melted my ground vtec solenoid wire?????????? (fastrunner)
well, when i disconnect one of the map sensors, the car runs funny.
When both of them are connected, the car idles fine.
what would you think>
Gant
05-18-2005 08:47 PM
