integra ITR 5lug hubs in civic knuckles?
Im in the middle of swapping to 5lug in my 93 civic SI (non-abs rear discs) and already have large brakes in the front so getting a whole "5lug" swap doesnt really make alot of sense to me. I also like the idea of having all new bearings - just one less thing i have to replace.
Im wondering if i can buy USDM integra ITR hubs (5lug) with new wheel bearings and use my civic knuckles?
Im guessing the integra and civic hubs (other then 4lug/5lug of course) are the same, as are the wheel bearings. I just wanted to make sure before i bought them.
Also..what about the rear hubs? Im guessing they are the same too.
BTW new hubs from honda are $106 each from majestic honda and wheel bearings are $30 each from a local import parts store.
thanks,
liam
thanks,
liam
Re: integra ITR 5lug hubs in civic knuckles? (JDM_Ej)
just get the ITR bearings...
I had new hubs and bearings pressed into my CTR 5 lug when I got it. I am 99% sure that the hubs and bearings will fit but I am not sure if the ITR calipers will bolt on to the civic knuckles... and you do need those...
Electrician
Re: integra ITR 5lug hubs in civic knuckles? (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">just get the ITR bearings...
I had new hubs and bearings pressed into my CTR 5 lug when I got it. I am 99% sure that the hubs and bearings will fit but I am not sure if the ITR calipers will bolt on to the civic knuckles... and you do need those...</TD></TR></TABLE>
Like i said above, i already have a big brake setup so i dont need the ITR calipers. I just needed to know about the hubs.
Thanks for the info.
liam
liam
Re: integra ITR 5lug hubs in civic knuckles? (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
well when you use those hubs you have to use the 5 lug rotors. which will need the ITR calipers.
You are doing this just so you can say that you have 5lug?
Do you have an AEM big brake kit?
Do you have an AEM big brake kit? </TD></TR></TABLE>
I have NSX calipers which have already been modified to fit my civic knuckles. I have been using prelude rotors redrilled, but now i can swap to using ITR rotors. The major reason im doing this is because my wheel bearings are shot anyways and finding ITR rotors is easier.
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V »</TD></TR><TR><TD CLASS="quote">or do you just want 5 lug in the back?
I don't get it... You have now confused me... </TD></TR></TABLE>
Im going to do 5lug in the back too - which is going to be a little harder then the front IMO.
Im not really sure what i can do there. Can newer prelude rear calipers with lude rotors fit on the civic trailing arms? Id be happy with using my stock civic SI rear brakes, but then i have to deal with the whole 5lug disc rotor issue.
liam
liam
I think you are just going to have to cough up the cash for the ITR rears...
JDogg
Suspension & Brakes
04-12-2008 08:57 AM
darrinbrewer
10-29-2007 08:17 PM
