help with mini-me swap (y8 head on D16y7)
i've searched and searched but all i can seem to find is the eg style mini-me (D15 to D16 head). so i have a few questions: ok i have the complete head, exhaust manifold, and ecu from a 2000 ex and i have a 98 cx. is there anything else i need for the head swap?
also every post i read about them it talks about wiring up vtec, what exactly do you need to do, i would just think since your swapping ecu's that there would be no problem?
and is the ecu just plug and play or do i need to get any special harnesses?
Re: help with mini-me swap (Hatchdude)
your going to need a 96-98 vtec ecu or get a jumper harness
you will to run a wire to your ecu for vtec, and vtec oil pressure, that should be about it but im not too sure with all this sohc ****, good luck
jdmcivicsi522
04-14-2006 06:05 PM
