<~~~OBD II 02 SENSOR~~~>
does any one know if it is "ok" to just tap the wire from the 2nd o2 sensor which is on the cat to the 1st o2 sensor which is on the Down Pipe?
I am plannining to just eliminate the 2nd o2 sensor.
Honda Civci 00 D16Y8
THANK YOU !!!
THANK YOU !!!
Re: <~~~OBD II 02 SENSOR~~~> (EE_Chris)
that works on the heater circuit only. they make o2 sims for this purpose, but they are notorious for not working well with obd2, since the ecu needs to see a certain difference in readings between the sensors.
