white smoke
white smoke
what does this mean? is white smoke good? or no?
i got a performance headers (stock exhaust) and air filter intake on my 2000 civic
bought the car like that, it runs great but when i floor the car and it hits vtec there's a white smoke that goes out on it specially on high RPM's
Modified by marc-111 at 8:57 AM 6/29/2005
Re: (marc-111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 »</TD></TR><TR><TD CLASS="quote">i only put reg water on my radiator
rings? piston rings? </TD></TR></TABLE>
aren't you supposed to mix coolant with water in your radiator?....could also be the head gasket
Re: white smoke (marc-111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 »</TD></TR><TR><TD CLASS="quote">what does this mean? is white smoke good? or no?
Not good, coolant/water burning. Now comes the fun part where you figure out where it's coming from. If it was the headgasket, it would smoke at any rpm, not just higher rpms.
Re: (marc-111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 »</TD></TR><TR><TD CLASS="quote">i only put a little coolant and fill it up with water
already changed the headgasket</TD></TR></TABLE>
White smoke is coolant, but with a bad HG, it would smoke all the time. Are you sure it's white? I get some very light gray / sometimes black smoke when I'm into VTEC or high RPMs; which is normal, and a pretty common occurence.
i see white on my rear view mirror on high RPM and when my dad followed me he also thick white smoke on high RPM's specially when it hits vtec
on low RPM's there's no smoke and the head gasket is like 1 month old
Re: (marc-111)
are you sure its not blue smoke (oil)? That is common at high rpms. a compression test can tell you if yuor rings are still good. try the compression test, and if the #'s are low, pour a little oil in the cylinders and do the test again. If the #'s go up, then your rings are on their way out.
Imperious: Mod of Valor
Re: (93allmotorcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93allmotorcoupe »</TD></TR><TR><TD CLASS="quote">
aren't you supposed to mix coolant with water in your radiator?....could also be the head gasket</TD></TR></TABLE>
This is what mine is doing now, I need a tune up. But I do believe it is my head gasket.
Re: (marc-111)
you can buy the kit at autozone real cheap, but I'm sure there's someone around who can do it for you if you want (it'll prob cost more than the kit though).
thanks! i tried searching and found this! >>> http://www.c-speedracing.com/h...t.php
it's on a GSR but i think it's just the same on a civic ex
thanks!
thanks!
Re: (marc-111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 »</TD></TR><TR><TD CLASS="quote">it's on a GSR but i think it's just the same on a civic ex
Good luck.
Good luck.
