Will a obd1 wiring harness fit into a obd2a chassis
Help on swapping obd1 engine into obd2a chassis EK
hey guys, i have a obd1 gsr complete and i was wondering what do i need to do in order to make it run in my 97 ek cx model?
i know this is a noobie question and that most people do obd2 to obd1 and i happen to be trying to do it the other way around and i am confused on some parts like the wiring harness. i would appreciate it, if i can get some information in order to complete my swaps and thanks in advance.... Detail information would be nice
Modified by sparco562 at 11:19 PM 9/19/2005
Modified by sparco562 at 1:32 PM 9/20/2005
Smack the guy who told you this.
The EK engine harnesses run through the firewall and plug in directly to the ECU. The EG/DC engine harnesses plug into the chassis harness while still in the engine bay. To get it to work with anything resembling simplicity, you'll need to use an OBD-2 harness of some kind.
Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
If you can locate the 96-01 engine harness then simply plug it into the engine and drop the engine in. Even though the harness is technically "OBD2" trust me it is a direct plug in for the 1992-1995 Civic on the underhood strut tower harnesses.</TD></TR></TABLE>
Would this be vice versa which allow you to use the obd1 engine harness with obd2a chassis (underdash harness to the ecu) with an ecu jumping harness?
sparco562
09-20-2005 09:11 AM
FritzInTN
07-10-2004 09:45 AM
