Tach revs at idle...
I searched to no avail...
My hatch recently started reving at idle on it's own. It's just a constant rev up to 2 grand then back to idle over and over again. It doesn't do it when i first start the car up, it seems like it has to get warmed up. Anyone experience this?
Thanks guys.
Thanks guys.
Re: Tach revs at idle... (BigRonDawg)
Wierd it sounds like im having the same problem tonight also. Might want to keep an eye on my thread also. Hopefully we get this fixed
https://honda-tech.com/zerothread?id=1375956
could be your IACV (idle air control valve), its a common problem w/ hondas. screen may be clogged. try cleaning the carbon deposits on the IACV screen. just remove it from the back of the manifiold (2 bolts), disconnect vacuum lines, clean it, put back on and see if it makes a difference
try these 2 links that might help if your still having problems.
http://www.findarticles.com/p/...83803
http://www.findarticles.com/p/...84454
Imperious: Mod of Valor
Re: Tach revs at idle... (jdm123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm123 »</TD></TR><TR><TD CLASS="quote">sounds like it could be a vaccum leak. happened with a friends of mines car after he swapped a gsr in.</TD></TR></TABLE>
Could be this. However, when it happened on mine, I adjusted my idle adjustment screw on the intake manifold and it fixed it.
Re: Tach revs at idle... (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
Could be this. However, when it happened on mine, I adjusted my idle adjustment screw on the intake manifold and it fixed it.</TD></TR></TABLE>
this is what i did yesterday and it has been fine since...
i hope it was the problem, i'll keep my eye on it.
if its not those .. just listen to the guy abotu the Idle Air Control Valve... my friends was having that problem and he replaced that.... also a vacuum leak is possible too... just go through and check
Re: (jdmpremonition)
I have the same problem, but it goes away after I'm warmed up.... and it only happens when I hit some gas before its warmed up.. 1.2k-2k rpm..... 1.2k-2k rpm..... up and down
it could be all those problems but deepding if your engine is moded with turbo or some sick na setup your car might be running to rich to the ECU at idle revs your car to compensate for the extra fule at idle when it is warmed up
Re: (Hebrew-Hammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hebrew-Hammer »</TD></TR><TR><TD CLASS="quote">mine dosnt start reving at idle until i mess with the throttle then it starts being gay.</TD></TR></TABLE>
exactly...
exactly...
well i took the TB off my car today determind to fix the reving problem, turns out that apiece of my old TB gasket found it was into the orphis to the iacv so i shot it dosn with some TB cleaner and swabbed it with a cotton swab now it all better. and i found that my TB was insanly dirty and i ahd just cleaned it out not even 100 miled ago. So i inspected and found that my airfilter had a rip in the inner linning leaving a hole for all sorts of things to enter my intake, since im broke i just mendid it with some fabric softener sheets till i get paid.
