motor question
motor question
Just finished my Mini mee swap...the car starts right up, but when you try to give the motor some gas, the motor just shuts off...Its a D16y8 head(stock) on top of a D16y7(stock)block...New d16y8 headgasket and D16y8 headstuds...i checked everything like 20 times know and it seems like everthing is right...
Car:1996 honda civic ex
Head:1996 D16y8
Block:1997 D16y7
Ecu:Stock P2P Ex
Walbro 255 fuel pump
STR fuel rail
Dsm 390cc injectors
Modified by boosted_ef at 1:21 AM 9/19/2005
Head:1996 D16y8
Block:1997 D16y7
Ecu:Stock P2P Ex
STR fuel rail
Dsm 390cc injectors
Re: motor question (boosted_ef)
this here is a link on how to do the swap...
http://www.jdmuniverse.com/for...32971
maybe you missed something?
i havent done the swap yet, so i dont know much about it...
hope this helps.
hope this helps.
Re: motor question (ROK801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROK801 »</TD></TR><TR><TD CLASS="quote">this here is a link on how to do the swap...
hope this helps.</TD></TR></TABLE>
this is the 3rd mini mee i've done....when i gas the car it just dies...
Re: (Ax3l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ax3l »</TD></TR><TR><TD CLASS="quote">All sensors ok? Does it get fuel at higher rpm?
Could it be the fuel relay that cuts?
I don't think so....When the car idles and you give it gas it just dies...i could be but i don't know whats wrong
Re: motor question (BigJ5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigJ5 »</TD></TR><TR><TD CLASS="quote">If you touch the throttle and it dies check the voltage on the TPS, see if it's in spec?</TD></TR></TABLE>
ok..
ok..
singlecamcrx
11-24-2004 08:56 PM
