ls swap in eg...which cat and radiator hose do i use?
im finally gonna get my car back and running and im going ls this time. it has stock header and i have a greddy evo catback. i cant run a test pipe yet cuz i have to go pretty much straight to the ref cuz i gotta smog my car in october so what do i do about a cat? do i have to go to an exhaust shop and have it extended or can i a stock cat and have it bolt up with out any problem?
also which radiator hose would i use for a civic half size radiator?
Re: ls swap in eg...which cat and radiator hose do i use? (93ejay1)
use a 94-95 cat converter and the 94-95 upper hose and bottom also. Um what model is the eg? mine is a VX and I had to swapp out my fuel pump. well I think it was just bad. But yea and you gotta repin the o2 sensor to a 4 plug. I still have to do that.
What I did was just bought a hi flow "fake" cat from ebay for like 30 bucks. I'm looking for a stock one cuz the hi flow is too damn loud and illegal. anyone has an offer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">great but what about the cat?</TD></TR></TABLE>
i had a ls swap in my coupe before
i used the stock cat from the ls
the swap came with dc headers
so with the dc headers and a oem ls cat i still used my thermal exhaust
Re: ls swap in eg...which cat and radiator hose do i use? (jdmchop)
Provided your exhaust didnt move location of the stock cat then it should bolt right up and you should be fine with the ref. I used my stock cat and passed.
Why don't you just buy it for a ls motor cause that's what you have, makes sense right?
Re: ls swap in eg...which cat and radiator hose do i use? (ThatsMyEG)
well im getting it swapped in tomorrow so ill have both cats but from what i understand the ls cat on stock headers will come up like 2 inches short of the catback and i have a greddy evo
it shouldnt because why would they make a aftermarket header that is 2'' shorter than an oem one? does not make much sense ha?
i know the gsr one is shorter than the LS could possibkle have the wrong manifold?
as long as you have a LS manifold on your LS motor with a LS cat then you should be fine cause you said you had a ex correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 »</TD></TR><TR><TD CLASS="quote">so an ls cat will work without extending it or anything? </TD></TR></TABLE>
what about a gsr cat? will that work too? my friend said any teg cat should work but then i read on here the gsr is shorter. stock ls header
