*P30 ECU REDLINING TOO LOW AND NO VTEC*
WHATS UP,
HERE'S MY PROBLEM: I JUST RECENTLY SWAPPED A USDM B16A FROM A 95 DEL SOL VTEC INTO MY 94 HONDA CIVIC EX(THE DEL SOL WAS MINE AND I DID THE SWAP SO EVERYTHING'S LEGIT). WHEN IM DRIVING THERE IS NO VTEC AND THE CAR REDLINES(FUEL CUT OFF) AT AROUND 7OOORPMS. IT SEEMS TO BE STUCK IN COLD START MODE. I'M THINKING THE CAUSE COULD BE THE THERMOSTAT(ORIGINAL) OR THE VTEC CONTROLLER BECAUSE I REPLACED IT WITH A USED ONE RECENTLY. WHAT ELSE COULD CAUSE THIS? PLEASE HELP. MUCH APPRECIATED.
Re: *P30 ECU REDLINING TOO LOW AND NO VTEC* (mintscorpion)
I don't know the actual cause of the problem, but I know that the thermostat wouldn't be the cause unless you never get up to N.O.T. Before I replaced my thermostat, it took a while to get there, but once I did, everything worked fine.
-Shane
-Shane
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">try removing the vtec controller so you have stock wiring and see if it works.</TD></TR></TABLE>
good advice.
do you have a CEL? (check engine light)
good advice.
acidburn2k2
12-10-2005 12:48 PM
