92 cx????'s
92 cx????'s
i have a 92 civic cx hatchback and i heard they have 9.8 gallon tanks ( someone correct me if im wrong ) and i been only putting in 20 bucks each refill because i figured it wasnt bigger than that well yesterday i was pumping off my credit card and wasnt paying attention and it went up to 11.3 gallons... is it possible for my cx to have a 12 gallon tank in it??
i think i do have one because usually where im at half tank would be is 140 miles now its around 210 at a half tank
Re: (civic_driver)
10 gallon for CX and VX and 12 gallon for the others as far as I'm aware. You are in California, though, and the California-specific Civics had slight differences than others. Of course, someone might have swapped in a larger tank intentionally or accidentally.
Re: (clm)
idk when i bougt the car it had origional 81,xxx miles on it and it was the origional owner... i think it is a 12 gallon tank tho because i know i dont have any fuel leaks.. but i have always thought that it was a 10 gallon.. idk maybe i have some wierd cx or somethin
1 Post
Re: (siregcivic)
I have a '92 CX also. I was under the impression that the CX had a 10.8 gallon tank, but after reading your post I looked through my HELMS and it says that all 92-95 civics have a 11.9 gallon tank, it doesn't specify anything in particular for the CX..?
The most I've filled up at the pump was 10.2 gallons, and I thought I was about to run out of gas before I made it to the station. Hmm..... I guess I can easily run it longer than 400 miles to the tank, with plenty of room to spare! Even though after about 10 gallons it's below empty on my guage.
Re: (MrTodd)
I have a '93 Civic CX and it holds somewhere in the vicinity of 11 gallons when I HAVE run out of gas..... so I dunno... I was thinking 10 gallons with some sort of reserve.
Re: (LSPoweredEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSPoweredEG »</TD></TR><TR><TD CLASS="quote">...with some sort of reserve.</TD></TR></TABLE>
Usually the fill tube, and whatever gas was already in the fuel line.
1 Post
Re: (Kendall)
So.... Does that mean the CX has a 10.8 or 11.9 gallon tank?
I remember my CRX had an 11.9, and filling up at the pump I was always putting in about 11 gallons, but like I said above I've never put more than 10 gallons in my civic.
Imperious: Mod of Valor
Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">11.9 for all 92-95 civics</TD></TR></TABLE>
Mine always takes about 9 gallons or so, even if it's all the way on 'E'.
Re: (JDM-EJ1)
there is no way that my tank is more than 10.5 gallons.. the most i've ever put in it was 10.1 when i coasted to the station because i had run out of gas..
Re: (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
Mine always takes about 9 gallons or so, even if it's all the way on 'E'.</TD></TR></TABLE>
same here it was sputtering and thats all she took
add a gallon of sludge on the bottom and you got it
those fuel gauges are there for an estimate.. they are not very accurate
you could probably go another 30-50 miles after the needle goes below empty... if it's an older car i wouldn't do it since the fuel pump might suck in a bunch of crap into the fuel lines
i got that number from helms and i know my 92 dx has an 11.9 tank.
Former Moderator
Re: (civic_driver)
According to honda's 1992 sales brochure the 92 CX/VX had a 10.0 gallon tank, while the DX/Si had the 11.9 gallon tank.
Not all 1992-1995 Civics have the 11.9 gallon tank.
Re: (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Can someone explain to me why my Civic has NEVER taken over 10 gallons even when it's on 'E'?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver »</TD></TR><TR><TD CLASS="quote">those fuel gauges are there for an estimate.. they are not very accurate</TD></TR></TABLE>
wow... whatever honda says... my friends crx hf wont take anymore than 6 gallons.. anyone care to explain that.hahahahah nah i know why... a dented fuel tank wont take much...
anyway.. i guess i have a rare cx than
1 Post
Re: (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">anyway.. i guess i have a rare cx than</TD></TR></TABLE>
Either that, or the gas station you filled up at is giving you the wrong numbers..
mycvc8u2
17
07-18-2003 09:35 AM
silverEH2
13
04-03-2003 12:24 PM
RATEDR
12
03-22-2002 04:29 AM
